Trackspec Motor Louvers 85-90 version
Subscribe
Aug 16, 2022 | 12:30 PM
So I bought the trackspec motor louvers and they are recommended to be put on a iroc hood but I have a rs hood and they said that could work how should i go about tackling it, should i remove the hood from the car and cut from the inside where it has the outline or if anyone has put them on a rs hood how did you go about installing them
Reply 0
Aug 16, 2022 | 02:19 PM
Re: Trackspec Motor Louvers 85-90 version
Check out LsxMatt (on here and on youtube) I believe he had an RS hood and installed these.
Reply 0
Aug 24, 2022 | 08:24 PM
Possible with a a grinder and some patience.
Reply 1
Aug 28, 2022 | 05:56 PM
you get any measurements of where they should be placed or did you turn the hood upside down and cut from inside there
Quote: Possible with a a grinder and some patience.
Reply 0
Aug 30, 2022 | 09:53 PM
I used the numbers one of my subscribers gave me.
you can't use the underside as a guide, it's not even close. Since you are using a RS flat hood, you can really put the louvers anywhere you want.
Reply 1
Subscribe
