I have a 83 Camaro that has broken louverd vents in the front bumper. Can these vents be bought new anywhere?
tia Mark
tia Mark
okfoz
close
- Join DateMar 2001
- LocationDoghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car87 Formula T-Top, 87 Formula HT
- Engine5.1L TPI, 5.0L TPI
- Transmission700R4, M5
- Axle/GearsSag 3.73, B&W 3.45
- Liked:197 Times in 142 Posts
I do not know about New, you can try the advertisers, www.hawksthirdgenparts.com and www.moderndaymuscle.com as a start...
You can also try Yearone.com and classicindustries.com, beyond that good luck.
John
John
Also to add to this is your '83 a Z28,Berlinetta or Sport Coupe. The reason i ask is the nose grills are unique for the Z28 but the Berlinetta and Sport Coupe share the same. Make sure you order the correct ones (or if Ebay ask before you bid ).
