Looking for NON A/C heater control for 85-90 Firebird/TA/GTA, intact and complete..
John in RI
close
- Join DateAug 1999
- LocationRI
- iTrader Positive Feedback100
- iTrader Feedback Score(170)
- Car1984 Camaro Berlinetta
- EngineLT1
- TransmissionT56 6-speed
- Axle/Gears4.11 LS1 Rear End
- Liked:469 Times in 363 Posts
Do you need cables ??
What is your ZIP code ??
I don't know if I need cables? do I? I'm deleting the A/C for an LS swap.
Zip is 16335-2651 residential
John in RI
close
- Join DateAug 1999
- LocationRI
- EngineLT1
IMO: You should re-use your original Heater controller. The non-AC blower motor/box works just fine with an AC controller.
The non-AC Controller - at least the 82-89 style - are cable controlled meaning there's no vacuum lines used to control the air delivery MODE. If you install one of these into a 82-89 with AC than you will not be able to adjust the air from the floor - to the vents - to the Deforoster.
I know the 90-92 Camaro used a vacuum operated non-AC controller.... but they have yellow graphics. I do not know how the 90-92 FIrebird non-AC controllers are built, but I ASSUME that they might be vacuum controlled as well. ( Might want to search for a Firebird 90-92 style non-AC controller. )
Hope this helps !
Hope this helps !
very helpful, and I will take your advice and leave it alone....thanks!
