Hey all, just a few quick questions about the dash swap. How difficult will this be for my Camaro? I'm running a '84 Berlinetta with the "H" 305. Can someone give a run down on the parts I'll need to perform the swap? I'd really appreciate any help you can provide. I'm really liking the idea of having built in cup holders and a glove box.
I hope you have a lot of patience. It was a nightmare for me. Got someone else to do it.
WheelsUp84z
close
- Join DateJul 2005
- Locationcurrently Jacksonville NC
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car91 z28
- Engine383 sbc, 88mm turbo a2w IC, CSU 750
- Transmissionth-400 PTC 4000 stall
- Axle/Gearsford 9" 3.55 gear
- Liked:0 Times in 0 Posts
Depending on what you want to keep/swap over depeds on how hard it is. Luckily for me i just gutted all the wires and a/c ducting and ran a new harness, makes it really easy. However if you wanted to try and keep all the hvac stuff and swap over the cluster...good luck! To get the dash to fit all you'll need is a dremel plus the dash itself.
It isn't all that hard just takes alot of time to getthings right.
