My driver side window acts kinda sluggish sometimes or doesn't want to come up at all, is this the window motor going bad or could it be the switch? I had this problem in a 4th gen Camaro and it ended up being the switch, yeah the motor eventually went out but at the time it was the switch that was acting up.
valicswarrior
close
- Join DateOct 2010
- LocationVirginia Beach, VA
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1985 Firebird S/E
- EngineSBC 350, mild cam Vortec heads
- TransmissionRebuilt 700R4 vette servo+shift kit
- Axle/Gears3.73
- Liked:0 Times in 0 Posts
if u need a motor check out discountbodyparts.com it was 11 bucks when i ordered mine
I'm not so sure that I need one but I guess if it's only $11 it won't hurt to replace it anyway just to be safe, then if I still have the problem I will know to replace the switch itself.
I had this same problem. Changing the switch is a lot easier than pulling the door apart.
And I didn't even replace the switch. I just removed it, disassembled it, cleaned the black arcing dust off the contacts using sandpaper, and lubed it up with dielectric grease.
Works perfect. Cost of repair - $0.00.
I like the cost of that even more, I'll give it a try and if it doesn't work then I will replace the motor. Thanks for the help and the tip on that site, I didn't know it existed. Checked the price of the motor and it was $16
