Back in 2015 I had this harness made from a member (Pocket) the harness is topnotch and never been installed. I no longer have the car (engine, trans and car was under 11 foot of water from hurricane Ida). Now I am selling all the left over parts.
The harness was made for a 1992 Camaro. The ECM was flashed for a 1992 also.
The harness is prelabeled
ECM Details
1995 5.7 LT-1 Camaro ECM Flashed by HawksMotorsports
(Recalibrate ECM 1995 LT-1 / 4L60E PCM, in a 1992 Camaro Removed VATS, Emissions, Gear 3.42, Cooling Fans, Basic Stock Program)
HARNESS BUILD SHEET
• Car, make, model, year:
1992 Chevrolet Camaro
• Original engine type:
1995 LT-1 pulled from a Camaro
• Original trans type:
4L60E
• Year of PCM being used:
1995
• PCM location:
Stock 3rd gen
• PCM routing
Stock 3rd gen behind the fender
• Trans type:
4L60E
• AC:
F/B-body low mount pass side
• Alt Location:
F/B-body
• Number of fans:
Dual
• Battery location:
Passenger side
• Relay center location:
Stock near booster
LT1 Swap Harness & flashed ECM
$775 shipped.
COMP Cams 1618-16 Ultra Pro Magnum Rocker Arms
$420 Shipped
(Seal open, but new. Box also damaged from being in storage)
93-97 Camaro Firebird V8 LT1 P/S Power Steering Fluid Reservoir
$45 Shipped
(Very Good Condition)
Comp Cams 850-16 Chevy Small Block + LS LS1 LT1 Hydraulic Roller Lifters Set 16
$250 shipped
DNJ TK3199 Timing Chain Kit 95-97 sbc
$75 Shipped (NEW SEALED)
COMP Cams Magnum Rocker Arm Studs 4502-16 $80 shipped (NEW SEALED)
BBK Performance Twin 58mm Fuel Injection Throttle Body, 1994-1997 GM LT1
$385 Shipped (Seal open, but new)
Universal Torque Converter Flywheel Dust Cover, for GM 4L60E 700R4 TH350 TH400
$25 shipped
EMAIL ME FOR PICTURES AND QUESTIONS AS I DONT LOG ON HERE MUCH\
DVolion11@gmail.com
ECM Details
HARNESS BUILD SHEET
4L60E
1995
• PCM location:
Stock 3rd gen
• PCM routing
• Trans type:
4L60E
• AC:
• Alt Location:
F/B-body
• Number of fans:
Dual
• Battery location:
Passenger side
Stock near booster
$775 shipped.
$420 Shipped
$45 Shipped
$250 shipped
$25 shipped
DVolion11@gmail.com
