Ls1 AC Delete
Subscribe
Oct 4, 2016 | 08:46 PM
Is there anything special that needs to be done with the HVAC harness when deleting the AC? I have the connector to the blower, the resistor, and the piece that connects to the main harness. Is it as easy as just cutting the remaining connectors off?
Reply 0
Oct 5, 2016 | 10:28 AM
Re: Ls1 AC Delete
Quote: Is there anything special that needs to be done with the HVAC harness when deleting the AC? I have the connector to the blower, the resistor, and the piece that connects to the main harness. Is it as easy as just cutting the remaining connectors off?
I just cut it out of my harness when I was prepping it, I think there are a couple parameters in the ecm that are based off of the ac when it kicks on etc that you would probably want to to tune out.
Reply 0
Subscribe
