69charger383
close
- Join DateAug 2005
- LocationConnecticut
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car2005 Lincoln LS, 83' Z28
- Engine242 DOHC and an empty engine bay.
- Transmission5R55S, T5 soon to be auto
- Axle/Gears3.58s and soon to be 4.10s
- Liked:0 Times in 0 Posts
I need the space on my Camaro for a turbo project. Does anyone know it its ok to remove the whole EGR system?? Also how old does your car have to be to e emissions exempt? Thanks, Baron
I believe the emissions rule is that if your car is 25 years old or older, than you are exempt.
As for the EGR question, CT does not conduct a visual under the hood for emissions equipment. The car is just put on a set of rollers and a sniffer is stuck in the tailpipe. If you have OBD II, they also scan the computer for any DTCs that may be stored.
Hope that helps.
Hope that helps.
