Anyone know NHRA rules w/in...
Subscribe
Feb 5, 2001 | 09:38 PM
Does anyone know,or have they run Russel twist lok hose(or Aeroquip&such) for their fuel system.I am using braided stainless steel line for the fuel delivery side,but want to use the russel line on the return side of the system.This is for a carb'ed car,so pressure at max with juice will be no more than around 8-10 psi.Any help is greatly appreciated!
Reply 0
Feb 5, 2001 | 10:36 PM
General regulations 1:5
All non-OEM fuel lines must be metallic, steel braided or NHRA accepted "woven pushlock". A maximum of 12 inches total of non-metallic or non-steel braided hose is permitted for connection purposes only.
NHRA accepted woven pushlock fuel line: Aeroquip FC300 and Aeroquip Star Lite 200.
Now nothing is stated if the lines are supply or return so assume the entire fuel system falls under the above rules.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Reply 0
Feb 6, 2001 | 08:21 PM
Thankx for the info Stephen,really appreciate it!
Reply 0
Subscribe
