Disappointing LG4 Results Inside...Need Help/Suggestions!
Subscribe
Apr 28, 2001 | 09:08 PM
Hi Guys,
Well I made my first trip to New Lebanon Valley Dragway, and my first run through the quarter mile with my car (see sig). My best run was a 16.619 @ 83.26 MPH. The 60' time was 2.438, I didn't detect too much wheelspin though, and my friends who were watching said the tires barely spun at all (I was basically launching it as I would on the street, definetly no more than about 1800 rpm, then flooring it) When corrected for elevation of ~1200 ft, the time is 16.41 @ 84.33 mph. Is this time reasonable guys? My shifting was solid once I got moving- I have a feeling my launch technique needs work. I was really expecting high 15's and in the high 80's for a trap speed. The car has 114000 miles on it, and I was shifting at 4500 rpm. I *think* the car has 2.73 gears (it turns 2000 rpm at ~60 mph). Let me know what you think of all this, and what I can do to improve the situation.
Oh, the timing was set to 5 or 6 BTDC @ 1000 rpm. And the track is in Eastern New York, temp. was about 60 degrees and sunny. Thanks in advance,
Steve
87 Formula Firebird - LG4, 5 spd
Mods: Edelbrock Open Element, Edelbrock RPM Catback, Arvin High-Flow Cat
Winter "Beater": 84 Delta 88 Royale Brougham
[This message has been edited by 87FormulaGuy (edited April 28, 2001).]
Reply 0
Apr 29, 2001 | 09:42 AM
You definately need to work on the launch! that 60' foot time isn't too great. if you can cut that down to a solid 2.1x time that would probably get you where you want to be.
Dont quote me on this part but i think you have a bit more than 2.73's. i have the same setup as you only with 3.23 and 2000 is about 65 +/-.
My 1986 Z28
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles!
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Reply 0
Apr 29, 2001 | 12:05 PM
I checked my RPO codes and i have 3.27 and my 60mph rpm is about 2000. try letting the motor wind up to 5000 (or whatever the redline is) before shifting. I know when i shift at 4500 instead of 5000 it makes about a .4 of a difference in my ET.
1988 Pontiac GTA 5.0 TPI
-K&N Filter
-Hypertech Air Foil
-Hypertech Perf. Chip
-2.5in Flowmaster Muffler
-Catco Hi-flow Cat
Maryland Int. Speedway Bracket Racing Trophy Winner
15.32@88mph
2.077 60-ft.
Kills
94 Probe GT, 95 Mustang GT, 96 Impala SS, 85 Thunderbird 5.0, 95 Accord V6, 98 Integra VTEC, 70 Chevelle Malibu, CRX w/ Turbo and Intercooler (have it on tape to prove it)
Reply 0
Apr 29, 2001 | 05:40 PM
Thanks for the replies guys. So it looks like I need to work on my launch technique, for starters...I was kinda babying it cause the rear end has some weird vibrations at high speeds, and my brakes aren't the greatest either. But I'll get those fixed for next time at the track, and try bumping up my shift points a few hundred RPM and see where that lands me.
-Steve
Reply 0
Apr 30, 2001 | 12:01 AM
Hmmmmm.....that's really odd.
You've got a setup almost exactly like mine, and I'm running a 15.6 1/4 mile time, with a crappy launch. (with 3.27 gears, before my 3.70's)
Check my sig below.
By the way, I've got a fully loaded IROC. Your formula should be lighter and faster.
I do have only 80,000 miles on it though.
"Doin 120 Mowin' over mail boxes, radar detector, to show me where the cops is."
"Ain't no such thing as a front wheel drive sports car...I can smoke the tires in my 1985 Accord with 87hp (factory rated)."
1987 IROC-Z28 Camaro
-ADS Super Chip-Replaced all fluids with Red Line Racing Synthetic fluids-Griffen "Nascar" Aluminum Racing Radiator-Good Year Super Hi-Miler Cooling Hoses-160 Degree Thermostat-Jet Fan Switch- Center Force Dual Friction Clutch-Hays Flywheel-New Alternator-Polyurethane transmission mount-Doors sound insulated with Dynomat Super-Replaced Ratted Hoodliner with new one from GM-Accel 300+ Spark Plug Race Wire with Pro-Sleeve -Bosc Platinum +4 Spark Plugs-305 H.O. Dual snorkel intake-Four Dunlop SP Sport 9000 tires (245/50ZR16)-New 3.70 gears in a Posi Rear End off 89' Trans-Am (Sandblasted and Painted Black with Yellow rear end cover)-Rear Disc Brakes (11.65 inch rotors with PBR Aluminum Calipers off 89' Trans Am)-Polyurethane bushings on rear sway bar-Catco free flowing high performance catalytic converter-Hooker Super Competition 3" Mandrel Bent Cat back exhaust-Replaced cardboard headliner with a waterproofed fiber glass headliner....much more comin' soon. =)
[This message has been edited by MikeDwhoROCZImports (edited April 29, 2001).]
Reply 0
Subscribe
