Dave do you think the t3o4e you used on your 3.1 was the best choice for a hp street engine. My 3.4 will have forged pistons[8.5-9.0 to 1] iron pp heads and a stock 3.4 cam.Can I run 15 psi on pump gas. I'm looking for quick spool-up with decent topend though ultimate topend power is not my goal. I found a garrett with 50/63 ar with 57 trim for a good price. I relize that turbos are like cams inthat whats right for one guy is not right for another so it best to get the opinion of some one that ran a similar setup.
if ur going with a 3.4 i recomend u goto a t61,though the t04e will work, it may choke top end power a bit.as long as u dont install 3:73+ gears the t61 will spool up pretty fast.
