PAXTON SN92, NOW WHAT TO DO WITH COMPUTER
Subscribe
Apr 29, 2007 | 01:07 AM
HI. I WAS WONDERING WHAT DO I HAVE TO DO WITH THE COMPUTER TO GET IT TO RUN RIGHT.. ALSO I WAS WONDERING IF 6PSI OF BOOST IS TOO MUCH WITH 10.5:1 CR?? THANKS..
Reply 0
Apr 29, 2007 | 01:34 AM
Re: PAXTON SN92, NOW WHAT TO DO WITH COMPUTER
1. Dont post a bunch of threads in all caps. I can see two on the first page alone. If you continue, you will not be taken seriously.
2. Your question in this thread is extremely vague. Give more info if you expect a response.
3. Consider grouping all of these questions into one thread.
Reply 0
Apr 29, 2007 | 01:44 AM
thanks for the input, and i only placed one thread in all caps and i wasnt thinking..so sorry.
as far as my question that i am having now is, how do i tune my computer to accept the boost. i have a maf system, and one guy said i have to use sd, but i see that a lot of systems use maf. thats i what do i have to tune my system.. thanks
Reply 0
Apr 29, 2007 | 02:28 AM
Alright. You can use a maf, but only up to a point. And I believe you want to make a drawthrough setup and not a blowthrough setup, as in have the MAF before the blower so it doesn't see boost. SD will be something you're eventually gonna want to consider.
You have a lot of computer options. If you feel like programming a standalone, you can look into megasquirt. There's also ROM tuning where you edit values in the binary file on the ecu.. I think there are a few stickies at the top of this forum where you can red more. And megasquirt's website is megasquirt.info or something like that..
Reply 0
Apr 29, 2007 | 02:41 AM
With 10.5:1 on iron heads, yes, 6 psi is too much. Heck, any PSI is too much. I'm guessing we're talking about pump gas?
That motor isn't really built for a blower is it? You can't just slap 'em together, it won't work well at all. Consider new heads with gigantic chambers, and or big dish pistons. And an intercooler. Then have fun.
Reply 0
Apr 29, 2007 | 10:39 AM
If you buy a new kit, you will not have to touch the computer at all. The MAF set up will run fine with the boost if it runs fine normally. You should start out with a larger pulley (lower boost) and work your way up to 6lbs.
Reply 0
Apr 29, 2007 | 05:41 PM
thanks for all the help.. im going to swap over to speed density, anyways, i think i will use an intercooler just to be on the safe side. and i m moving up to larger heads, to lower my cp to 9.8. thanks.. randall
Reply 0
Subscribe
