I have a 1988 Camaro with a stock 5.7 tpi and i just changed to the EBL computer.
I have a vortech supercharger i am going to install along with a bigger fuel pump and need a recommendation on what size fuel injectors to run.
I do have hooker headers and exhaust and i am going to have the manifold ported before putting it all together.
I will not be running a fuel management unit so i know i need bigger injectors, i just don't know what size.
Thanks, Rich
Thanks, Rich
How much boost? Probably looking at 300-400 whp depending on how hard you wanna push stock bottom end. May only need 30-36 lb injectors considering slightly richer mixture for boosted cars
I am not sure how much boost the Vortech puts out, my guess is 6 psi.
30-lb injectors will be just fine...
28lbs ones worked for me when the engine was mostly stock.
