Top down solutions Wonder Bar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
What a nice piece. I always had issues with my spohn unit fitting with the dual fans. With a test fit I gain enough room to get the fans on np. Spohn unit will be up for sale. This tds piece uses an extra bolt already on the frame rail. Recomended.
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Re: Top down solutions Wonder Bar
Agree 100%
White RS has a TDS wonder bar.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
How does it compare to the Global West unit?...
Transmission: Pro-built 700R4
I agree. Had mine on my GTA for several years. I have passed up on some great deals on other brands and instead insist on the TDS piece for my T/A.
Car: 1989 Pontiac Formula 350
One of the best things I've done for my formula was the TDS bar. Third bolt made all the difference on installation, too.
Car: 1989 IrocZ
Its a well made piece. Cant beat price and your supporting a vendor here. Get his greasable sway bar bushing kit too because it has to come off anyway. Gotta keep these vendors in buisness if they are supporting our hobby.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
I run a UMI wonderbar but like how the TDS unit bolts to the frame of the car.
Axle/Gears: 3.45, 3.27, 3.27
Thanks for the reviews and comments guys!
http://www.top-downsolutions.com/cha...or-firebird-(a
Lon Salgren
Lon Salgren
Car: '87 Trans AM GTA
Transmission: 700R
Just installed mine a few weeks ago. Great fit and great quality. Can't wait to drive it and feel the differencae.
Car: 1984 Trans Am
Engine: LS1383 in work
I've had mine for going on 10 years now and I really like it. My only complaint is that the paint is flaking badly and it's starting to rust.
Lon Salgren
Dangit. I just received the wonderbar for my T/A and remembered that I forgot to ask for a couple stickers when I ordered it. What a goober.
Car: 1984 Pontiac Firebird
Engine: none atm
Axle/Gears: 3:73 zexel torsen
Are these any different than the ones that come with the Irocs? I ask because I have a wonderbar from an Iroc that I was planning on installing in my Firebird. If these are better I might consider TDS.
Yes. Compare.
TDS steering brace (aka WonderBar): Exclusive 3 mount bolts used per side (only brace that actually bolts to the front subframe, all others bolt to a bracket that is bolted to the frame) 1" center tubing, powder-coated or zinc plated.
GM wonderbar: 2 mount bolts per side. .75" center tube.
More info on my website under "Chassis and Suspension" category.
Lon Salgren
Lon Salgren
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
yup. ive had mine on the car 10+ years love it no complaints
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Never seen this brand before. I have a spohn unit on my car. I have no problems with it besides for how I cannot get the passengers side poly bushing to close fully. Don't think it has to do with the bar but still frustrating. Anyone know of that's like really bad that it's not fully closed? Has like a 5mm gap.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I like the TDS products.
Really nice bar but this one's not too shabby either.
= https://www.thirdgen.org/forums/afte...r-bar-1-a.html
Lon Salgren
Remove the bushing and measure the ID.
Lon
Lon
Engine: Slow ones
I did awhile ago. It was like 35.??? Almost 36. Called spohn and they said that they hone them out to be 36.
Alaska Hwy 1Le
Oct 7, 2016 12:49 PM
Tibo
Sep 14, 2016 08:19 PM
