Any 1LE for sale???
Old Aug 24, 2017 | 06:57 AM
  #101
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: Any 1LE for sale???
So this is something I haven't seen before - the cam chart in the link that Jeremy posted up.
Am I reading this correctly that the 90-92 G92/1LE cars got an even better camshaft?
Old Aug 24, 2017 | 08:05 AM
  #102
Yes its better than non G92 cars but is also the same used in the 350 cars.
Looks like the 88-89 350 auto/305 tpi 5speed cars (w performance) still have a bit bigger cam than the rest.
Old Aug 24, 2017 | 08:15 AM
  #103
I'd take any cam specifications with a grain of salt, especially without the original source being disclosed. That said, most of what I've seen suggests that the late MAF cars got the "biggest" cam. I'm not sure how much the specs really matter though, since they only tell so much.
Originally Posted by jeremyb1988
Ur like Drew, he dosent want to show me his cars either smh....
It's an older photo, but representative. Replace the gunmetal 91 Firebird on the end with a dark metallic green 91 Firebird, and it could almost pass for current.
Old Aug 24, 2017 | 08:50 AM
  #104
82tarecaro's Avatar
Old Aug 24, 2017 | 08:51 AM
  #105
jeremyb1988's Avatar
On Probation
Car: 1987 IROC-Z Camaro
Transmission: T-5 5 Speed
Only need 3 more to drive a different one every day of the week
Old Aug 24, 2017 | 08:55 AM
  #106
On Probation
Originally Posted by PurelyPMD
Check your SPID tag for the RPO 1AZ - that denotes a sold (customer) order and would give the car a higher priority in production. My 87 was a sold car (me) and has that code - my 91 was special ordered by a female Delco executive in Rochester and she wanted the leather seats and rear defroster (and since she didn't need A/C in Rochester NY got the 1LE).
You may also want to look for the build sheet in your car - if it is a Norwood built car it is likely under the carpet on the floor in the back seat.
It does have the 1AZ code...sweet learned something new
Old Aug 24, 2017 | 05:12 PM
  #107
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Opening up the 1990 GM Tech Sheets from the Player's series <insert church music> ...
1. Engine
- New Speed density calibration eliminates mass-flow sensor (lower cost, better reliability & air flow)
- Slightly milder camshaft improves idle quality and offsets increase air flow due to speed density calibration, giving same power as 1989.
2. New calibration prom to match engine changes provides similar characteristics to previous years, except that shift-light raised to 5,200 RPM.
Mark.
Old Aug 24, 2017 | 05:57 PM
  #108
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
From earlier in the thread - how did these cars ever get 26 MPG on the highway?? With my stock 305 I was getting 12 MPG city and 15 MPG highway from the time I bought it until I swapped out the motor. With the new 305 I get more like 16 city and 19/20 highway.
Old Aug 25, 2017 | 02:31 AM
  #109
KMK454's Avatar
Car: 1991 Camaro B4C
If your car is running correctly and you hold it to 55 MPH, you'll get great highway mileage.
Old Aug 25, 2017 | 03:35 AM
  #110
indy82z's Avatar
This is true!! I got nearly 30 mpg with my 5.0 TPI 5 speed Iroc on a trip to Indy for a car show years ago. I think I had my cruise set around 55-60 the whole way. I thought my gas gauge quit working since it was moving so little.
Old Aug 25, 2017 | 02:16 PM
  #111
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
When I bought my 89 Formula 350 convertible, I drove it from Asheville, TN to Flint MI. I averaged 25.8 mpg. 70mph top up
Old Aug 27, 2017 | 06:19 PM
  #112
On Probation
Sorry when you said Flint Michigan all I could think of was that movie Semi-pro and the Flint Michigan tropics...
Old Aug 28, 2017 | 10:41 AM
  #113
okfoz's Avatar
I never watched that movie, I remember the name, nor have I ever watched "Roger and me" Which was about Flint...
John
