85 z28 wheels for stock suspension/brakes
Car: '85 Camaro Z28
Engine: 355 carburated
Transmission: TKO600
Axle/Gears: GTA rear, 3.73 posi, hotchkiss
Suspension and brakes are stock for now. Looking to upsize rims to 17"s in anticipation of a future brake upgrade that has yet to be decided (probably 1le, C4, or wilwood conversion). I will likely lower it as well but not anything crazy, just an inch or 2. Mainly a street cruiser with the occasional track/autocross day. Its not a drag car. Mainly im looking for widths, offsets, and backspacing that will work with stock, and wondering if the same rims will work once i change the brake system.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Re: 85 z28 wheels for stock suspension/brakes
Check these out:
https://www.ctw-motorsports.com/
The wheels are 17" x 9.5" and will fit stock brakes and also just about any aftermarket kit out there. Used with great success on autocross cars and weigh several lbs less than other wheels of the same size.
Car: '85 Camaro Z28
Check these out:
Nazzz28
Apr 12, 2007 04:56 AM
