1984 Z28 Repaint - Photo Documentation (High Res Slow to Download)
Old Oct 1, 2017 | 09:36 AM
  #151
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Transmission: 5 Speed
Axle/Gears: 3.23 Truetrac; was better w/ 3.73
Re: 1984 Z28 Repaint - Photo Documentation (High Res Slow to Download)
Old Oct 1, 2017 | 11:10 AM
  #152
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Do a search on TGO for cowl color. Many years ago, we documented what cars, from what years and plants had the black cowls. If I remember correctly, the 1988 cars started having the cost savings of non painted cowls.
Old Oct 9, 2017 | 06:09 AM
  #153
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Factory used adhesive around the drip rail attachment points. I didn't want to use messy adhesive, so tried butyl rubber. Below are progress photos and not the final product. By the time was finished it was more smooth and gradual surface to blend with pending foam tape of the metal window seal channel. But next time I'd slightly reduce the thickness of butyl between the drip rail attachment point and the red painted surface. Will do that on the passenger side. I think it'll be OK as is. Want to keep water from moving from outside to underside of the attachment point and sitting in there.
Old Oct 9, 2017 | 06:13 AM
  #154
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Old Oct 9, 2017 | 06:17 AM
  #155
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
In the next photo it looks like there might be a slight gap between foam and red paint. This is from the interior side, so might be tighter toward outside of the car. The foam may compress some. I'll check the tightness of the seal channel screws before installing window seals.
Old Oct 9, 2017 | 06:22 AM
  #156
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Old Oct 9, 2017 | 06:25 AM
  #157
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Old Oct 9, 2017 | 07:30 AM
  #158
scottmoyer's Avatar
I hope those aren't scratches on the roof, four pictures up!!!
Old Oct 9, 2017 | 08:31 PM
  #159
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Not yet. Reflections of the garage door opener safety eyes wires. Car has been getting dusty. Not washed once. Not misted once. Picked up a few rain drops the other day. Slow restoration any more. Spend more time driving it on weekends then working on it. Too much fun. Only work on it when I want to, not because have to. Will finish interior in spring. Stripes thereafter. Winter storage will put all to a stop until April. Sucks. Will get a good soap and water wash before covering. That reminds me. Need to get a cover.
No doubt I'm an amateur restorer. Everything I do is new. Second time generally seems easier. But designing an implementing each revision from factory construction is challenging. The challenges revolve around improving the factory assembly processes. Duplicating what GM did would be much easier, but only as robust as these cars were back in the day. NOT.
Old Oct 15, 2017 | 06:34 PM
  #160
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Window seals are in. Door seals are pending, as are window position and door striker adjustments. But nearly mouseproof in advance of winter storage. Front GFX and rear bumper cover also need minor adjustment.
Stripes and decals go on in spring, along with interior insulation and interior reinstall.
Oh yeah, need to get the fender liners in before driving to storage.
Ha! And grills are missing.
Old Oct 26, 2017 | 06:00 PM
  #161
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Door disassembly photos for reference.
Old Jul 29, 2018 | 07:27 PM
  #162
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Old Jul 29, 2018 | 07:34 PM
  #163
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Old Jul 29, 2018 | 07:43 PM
  #164
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Old Jul 29, 2018 | 07:50 PM
  #165
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Old Sep 2, 2018 | 05:36 PM
  #166
bonemaro88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 305 TBI
Transmission: Manual
Axle/Gears: 3.08
It's awesome to see the interior coming together.
Old Sep 2, 2018 | 05:55 PM
  #167
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Been working on variety of things from interior to drivetrain to body and glass alignment. Have not kept up with posts here. Drivetrain has taken up enough time that the interior progress retains the empty shell look. Hatch carpeting is in.
Old Sep 2, 2018 | 11:20 PM
  #168
Why all the individual small pieces of dynomat, instead of covering bigger areas with larger pieces?
Old Sep 3, 2018 | 07:17 AM
  #169
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
The butyl rubber doesn’t help with heat and little with engine and road noise suppression. It reduces panel resonance which helps that noise range. It is heavy and robs from the formidable L69 performance package with 190 HP at the crank and residual power at the wheels. Using Dynaliner closed cell foam rubber over top for suppression of heat, and road and engine noise. Will attempt full coverage with Dynaliner, installing it wherever not limited by thickness and monetary constraints. Most likely a lack of sense will result in full Dynaliner coverage
Old Sep 3, 2018 | 07:18 AM
  #170
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
I tap on a panel and if it resonates I install Dynamat. Darned near close to full coverage anyway in some areas. But I also like ability to remove areas later if needed. And do not want large areas where water could collect beneath should that ever happen.
Downside is some day heat could cause the smaller pieces to come loose. Cars will be much different by the time it happens to any significant degree. I’m also trimmming corners rounded, when i remember, to reduce corner peel and droop should that day come. With modern adhesives I doubt any of this will be an issue.
Old Sep 3, 2018 | 07:46 AM
  #171
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Old Sep 3, 2018 | 07:53 AM
  #172
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Old Sep 3, 2018 | 08:02 AM
  #173
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Regarding the Dynamat I avoid all body seams, body plugs, interior mounting points, and where added thickness might be an issue. Any point that could require future access or service is not covered.
Old Sep 3, 2018 | 07:34 PM
  #174
Oh, ok. So there IS a method to the madness. You are doing great work.
Old Sep 3, 2018 | 07:47 PM
  #175
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Mostly madness.
Old Sep 4, 2018 | 06:44 AM
  #176
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Speaking of madness, the goop swirl here was installed by the crack team at GM in June 1984. Since it survived a full quarter panel replacement it seemed fitting to stay in place.
Old Sep 4, 2018 | 08:41 PM
  #177
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
How in the world did they get the doors bolted to the frame with the fenders on???
Asking for a friend lol
I thought about doing that myself so I can paint and not have to deal with the whole fender alignment thing without damaging the paint but can't see how I would be able to bolt the doors on while the fenders are on.
Old Sep 4, 2018 | 09:01 PM
  #178
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Was not fun getting a couple hinge bolts back in. But did it after some struggle and a lot of yoga type moves. And acceptance of arm bruises and scrapes. Won’t do that again. Hopefully won’t be a next time.
Old Apr 8, 2019 | 06:17 AM
  #179
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Home for the season. To me the red looks brighter than factory 75U. May be a factor of modern paint. Or it is simply a brighter mix.
A lot to do. Will be striped within the next 60 days. Need to break up the vertical body seams with horizontal stripes and possibly body edge guard. Much interior installation to do. But focus will be getting this 72,000 mile car to drive better with front suspension and steering rebuilds. New tires are Cooper CS5 Grand Touring. Much improved over the 8 year old Cooper Cobras.
Old Apr 8, 2019 | 09:04 AM
  #180
scottmoyer's Avatar
My personal preference would be to NOT install the door edge guards, The '82 - '84 either had no door edge, had a black edge or the dealers would install an aftermarket one that got riveted to the doors. After all the work you've done, I'd leave it blank.
Regarding the suspension, I upgraded my '82 with the 36mm and 24mm sway bars and I feel a major change in the handling. Once I put low profile, wider tires on, I'm sure the feel will be even tighter.
Old Apr 8, 2019 | 10:52 AM
  #181
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Appreciated.
No body side mouldings would mean one less thing to do. April 2017 was the start of disassembly. Past experience says these cars are way more fun finished.
Hoping the stripes go a long way to break up the red, and carry the eye across. For me an early car needs stripes.
Old Apr 8, 2019 | 07:58 PM
  #182
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Originally Posted by Saxondale
Appreciated.
My car didn't come with body side molding, but sometimes I wish it did. I actually like the looks of them, but it's just one more PITA when you try to chamois off the car.
I have an almost complete set of NOS GM orange stripes I'd sell cheap. Otherwise, I'd recommend a Phoenix Graphics kit. That's what I have on my car and it's pretty good stuff. I dont think it's as good as OEM, but its probably the best for aftermarket.
I would recommend door edge molding, though..
