WTB 84-88 Steering Column
Old Sep 29, 2014 | 05:56 PM
thejacobwashere's Avatar
Car: 84 Camaro Z28
Engine: Chevy 305
Id like to buy a column for an 84-88 third gen, i recently bought one from an 89 and got screwed because the tilt wheel had a ton of play in it. Looking for one in good condition with a key, working wipers, turnsignals etc. so i can just bolt it in and enjoy my car again! also must be tight with no play in it. Let me know what you guys have and how much you are asking. Located near Greensburg, PA will drive about an hour but any further it will need shipped/
Old Sep 29, 2014 | 06:22 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: WTB 84-88 Steering Column
I have one in good condition. The tilt is tight and has a key. Edit: print on stalk has fade. Can't guarantee the signals, wipers etc., but have no reason to doubt that they work. If there is a way to test them with a meter I can do that, just let me know what to do.
The leather steering wheel was like new so I imagine the rest of the car was well taken care of.
PM me if you are interested and/or want pics. Actual zip helps more for shipping estimates.
Attached Thumbnails WTB 84-88 Steering Column-1984-column-01.jpg   WTB 84-88 Steering Column-1984-column-04-sm.jpg   WTB 84-88 Steering Column-1984-column-connectors-sm.jpg
Old Sep 29, 2014 | 07:42 PM
Scorpner's Avatar
Engine: V6, V8
It only takes three images and has a size limit too, so I made a composite image to fit it in.
The middle image is the high beam switch and clicks when depressed, it is partially installed. The other rod is is for the ignition switch which is not included. The key is not original, but is the "A" version in case you are interested in the period of the cylinder. The fade can be seen in the other pic but is not very clear -sorry. I was in a hurry as I wanted to get something before it became too dark. the last pic shows that the horn receiver is in good condition.
Attached Thumbnails WTB 84-88 Steering Column-1984-column-comp-02   WTB 84-88 Steering Column-1984-column-high-beam   WTB 84-88 Steering Column-1984-column-horn-plug
Old Sep 29, 2014 | 10:19 PM
Car: 84 Camaro Z28
Engine: Chevy 305
im sorry im not exactly sure what you mean by the ignition switch is not included, is that at the bottom of the column and i will be able to swap my old one in easily? Also how much are you asking? my zip is 15473...its a Pennsylvania zip. Thanks!
Old Sep 29, 2014 | 11:22 PM
Scorpner's Avatar
Engine: V6, V8
I sent you a PM.
Old Sep 30, 2014 | 11:56 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a couple good complete 84-88 columns.
Old Sep 30, 2014 | 12:13 PM
Car: 84 Camaro Z28
Engine: Chevy 305
i have found one. thanks guys! this thread can now be closed.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
