T56 Swap Flywheel
Old Aug 9, 2015 | 12:24 AM
BlackphantomZ28's Avatar
Car: 1985 Z-28
Engine: 350 4bbl
Transmission: t-5
Axle/Gears: 4.11
T56 Swap Flywheel
I have a used spec flywheel for sale which is needed for the t56 conversion this will work on all motors 1 or 2 piece as it will come with weights if you have a 87 and up motor your putting it in.
225 shipped i paid 400 plus shipping on this
Old Aug 10, 2015 | 12:40 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
Re: T56 Swap Flywheel
can you confirm if this is the: SC66S model?
Old Aug 10, 2015 | 06:12 PM
Car: 1985 Z-28
Engine: 350 4bbl
Transmission: t-5
Axle/Gears: 4.11
I looked for a serial number but couldn't find one on the flywheel it is used so it could be there I'm juat missing it.
Old Aug 27, 2015 | 02:27 AM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Can you measure the bolt pattern diameter? It won't work on all motors; the one and two piece RMS cranks have different bolt patterns. If the bolt spacing diameter is 3", it's for a one piece RMS crank; if it's 3.58" it's for a two piece.
Old Aug 31, 2015 | 10:29 AM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Correct el_muerte,
this only has a 3" bolt circle.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 31, 2015 10:31 PM
19irocz85
Aug 26, 2015 07:54 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
