[FL] PCM, 700r4 Speedo Kit, bushing kit
Old Jun 9, 2016 | 10:16 PM
IROCUDREW's Avatar
Car: 1989 Chevorolet Iroc-z convertible
Engine: 383, holley terminator efi
Axle/Gears: stock 10 bolt w/ 3.73
700r4 recalibration kit - SOLD
ECM Serial # 01227165, Memcal AUJN - $49 Shipped OBO
Memcal code is "AUJN 1615 0502" is from a 1989, automatic, 3.27 gear ratio, F-body. Table for TPI Memcal codes http://chevythunder.com/prom_bcc_1989.htm
Also it comes with the plastic bracket and the one cover screw is stripped, doesn't affect anything.
https://imgur.com/Z5vTJMePolyurethane Track/Panhard bushing kit &
Rear lower control arm polyurethane bushings - Both for $45 Shipped OBO
https://imgur.com/1xATEZz
https://imgur.com/knwwFPB
Old Jun 13, 2016 | 03:02 PM
IROCUDREW's Avatar
Re: PCM, 700r4 Speedo Kit, bushing kit
Bump
Old Jun 15, 2016 | 04:28 PM
greasegrenade's Avatar
Car: 89 Iroc,
Engine: 5.7 TPI
Axle/Gears: 327
what year model did the ecm come from and is the prom in it?
Old Jun 26, 2016 | 10:58 PM
IROCUDREW's Avatar
Yes, the prom is in it and I am not 100% on the year for the ecm as it came out of my camaro that had a corvette 350 installed before I purchased it. The car ran great with the ecm installed and have no doubt it is a 350. However I do not know how to verify if it is from a 350 or a 305.
Old Jul 4, 2016 | 12:03 PM
vtwinsroc's Avatar
Car: 86 iroc,89iroc,98z28
Engine: 305,305,ls1
Transmission: 700r4/4l60e
Axle/Gears: 2.77/3.23
I p.m you
Old Jul 5, 2016 | 12:24 PM
IROCUDREW's Avatar
I opened up the pcm to check the memcal code. The code is "AUJN 1615 0502". I found a table on chevy thunder that has a list of prom codes. From what I read there it seems that the prom is from a 1989, automatic, 3.27 gear ratio from a F body. I'm not sure what the second and third set of numbers stand for. Here's the website I found it from http://chevythunder.com/prom_bcc_1989.htm
If anyone has insight on the other numbers please let me know.
1Aauto
Sponsored Vendors
Jul 27, 2016 01:25 PM
