Manually open hatch
Old Today | 02:52 PM
DigitalDan3's Avatar
Manually open hatch
I found a rear spoiler and taillights at a salvage yard. We hooked up a jump pack to the car and tried the hatch release but no luck. No keys either. What is an easy way to get it to open? Don’t care if the panel inside is ruined or the hatch lock
Thanks in advance,
Dan
Old Today | 03:28 PM
scottycamaroz28's Avatar
Car: 89 PONTIAC TRANS AM
Engine: 5.0 TPI
Transmission: Stock 4SP 700R4
Axle/Gears: 4TH GEN 3:23
Re: Manually open hatch
If you dont mind crawling back there to the hatch area you could rip off the back interior panel and use a small screwdriver to release the latch or turn the tumblers. If you dont want to crawl back there and you are carefull as well as good with a decent flat blade screw driver and a hammer you could pound out the lock cylinder to pop the hatch that way. i stress the GOOD with hammer and screw driver becase one slip and there goes your tail lights or center tail section.
Old Today | 05:49 PM
Thanks in advance,
Dan
Thank you!
turd_gen
Feb 22, 2016 10:17 AM
Mr.84TransAmer
Southern California Area
Nov 14, 2008 12:46 PM
Z28cross-fire
Aug 18, 2006 09:33 PM
ontogenesis
Aftermarket Product Review
Oct 5, 2003 07:08 AM
