i know you cant swapfront to rear but can i just remove the left wheel and tire and swapit directly to the right....the right has a little wear on it
...and i cant afford new tires right now...the ones i have suck bad...so i am saving for some good ones...
...and i cant afford new tires right now...the ones i have suck bad...so i am saving for some good ones...Yes its called rotating the tires.
the proper way to rotate tires is to do opposite corners...but on a 92 rs you have to remove the tires from the rims to put the rear on the front because of the backspacing on the rims...i am wondering if the backspacing is the same on both rear rims so i dont have to have the tires removed and rebalanced..maby i wasnt clear enough but i may as well just try it and see for my self if im going to get BS answers like that...thanks
im sorry maby i took that wrong...im really not an A$$..but the way that read seemed like an insult...like i said sorry if i misinterpreted...
Yes the rears are the same. The front and rears on the 16" have different offsets. The fronts both are the same as well as the rears. Now if you have directional tires and different offets or different sizes front and rear you have to have the tires dismounted.
Its called rotating the tires...
LOL, let's make this simple:
Quote:
If your tires are not directional, yes. Originally posted by dwillis
