hey i know it sounds stupid to drop wheel size but i am building an 85 camaro with a 2.5 for a mini stock and we are required to run 13 inch wheels they can be 2 inch backspace at a max. will these clear the brakes just wondering if anyone knew
Gallileo60
close
Wow, never heard of that before...Good luck..Someone on this board will know...
I doubt a 13" wheel will clear factory or any aftermarket brakes. Are you sure a third gen qualifies for mini-stock. Sounds like it's a class designed for small imports. You "might" be able to get a 14" rim on the car and I doubt you'll even find a 13" rim with 5 on 4-3/4" bolt pattern.
First welcome to the board.Does the Camaro really qualify for "Mini-Stock" class?I agree with Stephen I don't think 13" wheels will clear the factory rotors/calipers.Check your class rules if they allow the smallest factory wheel/tire,P195/75-14 I believe,package the car came with from the factory.
ya the camaro qualifies right now we race cavaliers but now one has ever tried the camaro because of the rareness of the 4 cylinder version. i am having custom wheels made with the bolt pattern. and no we cant run any 14 the tire we have to run is a track tire it is a 215/60/d13 american racer treaded race tire. if the brakes wont clear i will build something to hold a cav spindle and brakes or something but i dont want to involve it that much right now
