Adjustable suspension
Subscribe
Oct 26, 2000 | 12:20 PM
Does anyone know where i can find a completly adjustable suspesion for my thirdgen. Such as airbag kits, or coil over kits. Also on our camaros is there a comparable suspesion setup on other gm cars or trucks such as an s-10.
BiGdAdDy
Reply 0
Mar 17, 2001 | 11:29 PM
I was suching for the answer to his question when I saw it had not been answered. I figured if I replied someone might see it and be able to answer.
Also how much would an airbag kit be? Whould it have the controls to raise and lower also?
thanks
Joey
Reply 0
Mar 18, 2001 | 12:22 AM
I've never seen a kit available for a specific model such as an f-boby but a similar kit for something like an older impala would probably work since it also is a coil spring car.
You can get helper air bags that fit inside the rear coil springs. They'll help when you have a heavy load in the back. Drag racers also use them to fine tune the rear suspension.
Front coil over kits are available from places like www.paracing.com. Rear coilover kits require some sort of chassis fabrication since they are usually used with ladder bars or a 4-link.
The closest GM car rear suspension to a third gen is an H-body. The old vega and monza used a torque arm system similar to the third gen f-body but no suspension parts are compatible.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Reply 0
Subscribe
