What kind of stall speed should i get
Subscribe
Jul 24, 2000 | 07:10 AM
I know i need a new torque converter after all the mods i did this winter but im not sure what stall speed to get. I put on new heads,headers,cam,lifters,throttle body and a bunch of other stuff. The trans is a 700r4 in an 87 IROC 305 TPI.
Reply 0
Jul 24, 2000 | 08:14 AM
What RPM range does you cam and heads pick up at. If its like a 2500-5500 Rpm set. Like Edelbrock's first kit. With carb heads and cam. The get a 2000-2500 RPM converter. If you have went crazy on mods go a little higher in the RPM range.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Reply 0
Jul 24, 2000 | 08:19 AM
get your car dynoed to see where your peak torque is, then get a stall thats 500-750 rpm lower than that number. if you cant dyno your car its all guesswork then
if you got a performance package like from edelbrock then you can use the chart they gave you
Reply 0
Jul 24, 2000 | 08:24 AM
The heads i put on are World Products S/R Torquer 305 heads. And the cam is a crane compucam with 208/214 duration @0.050"
Reply 0
Jul 24, 2000 | 11:45 AM
Reply 0
Jul 24, 2000 | 12:55 PM
Another WAG is a couple hundred RPM's above the lower end of the cam power range, assuming everything else matches the cam (you don't have 1-3/4" primary headers, by chance?). That sounds like a fairly mild cam, so 1800-2000 would probably do. If you over-did it on the header primaries, or your gears are a low number like 2.73, you could benefit from a higher stall than that.
Reply 0
Jul 24, 2000 | 02:25 PM
If you race the car, I'd run as much stall as you can stand. If not, then call a convertor company for a recommendation. For your combo I'd say 2500 and up.
A good rule of thumb is to add 500 rpm to your minimum operating range rpm, and use that as your stall speed.
Reply 0
Jul 24, 2000 | 05:05 PM
I have the same exact cam in my new "ZZ4" 350 with Edelbrock Performer heads, Holley 670cfm TBI and SLP 1-5/8" headers. I will soon have a 3.42 gear & Auburn Pro posi.
I chose a Hughes 2200-2500 stall converter based on a recomendation directly from Hughes Performance after I explained my setup to them.
Reply 0
Jul 24, 2000 | 11:41 PM
I will give another vote for the 2500 RPM. Thats a good speed where it gets you out of the gate quick with minimal tire spin.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Current Mods: Edelbrock TES Headers, Hooker Cat-Back System, Performance Resource Chip, 160* Thermostat, Accel 8.8mm Ignition Wires, K&N high flow air filters, gutted air box, gutted MAF sensor, Throttle Body Coolant By-Pass, Homemade Ram-Air, Falken ZIEX Z-Rated Tires.
1/4 mile times without chip:
Best ET: 15.7 @ 89MPH
Best Corrected ET: 14.5 @ 96MPH
Reply 0
Subscribe
