Those who've run skinnies up front
Subscribe
Jul 27, 2000 | 02:40 AM
I am interested in hearing about experience running and or discussions you've had with tire manufacturers/engineers etc. about running high pressures on 24-3.6-15 or similar front runners. We are getting ready to run a set of M&Hs in that size on Centerline Warrior Pros in 3.5-15 on a land speed car with about 1500 lbs static on the front end. Wheels are 'Strange' spindle mount type with the single retaining nut. Box says 60 psi max for seating (40 in CA). Can you run 80-100 psi with this setup?
Rolling resistance turns out to be quite an issue not far behind aerodynamics up in the 200mph range.
Reply 0
Subscribe
