these are my times, I can't figure out why my car is falling on its face after the 1000 ft.
RT-.757
60'-1.987
330'-5.863
1/8-9.094@74.50
1000'11.90
1/414.27@96.83
What gives? Ideas anyone? If you need anymore info let me know I will be more than happy to provide it.
P.S. Times were on 3.42's
RT-.757
60'-1.987
330'-5.863
1/8-9.094@74.50
1000'11.90
1/414.27@96.83
Doesn't seem like you have enough cam for 3.73's, also you don't mention the heads you have either.
Seems to me like you're actually running well with a TBI'ed engine.
Head are stock heads from a 89 chevy PK....engine builder said 1.94 1.6 valves.........350 btw, thoes runs were with 3.42 gears also.
Heads come off of a 89 350 pickup, Engine builder told me .194/160 valves. That run was with 3.42 gears also,
Swirl-port garbage. Those are just about the worst possible heads you could have for a performance application regardless of being equipped with valves of the stock 350 size. They have no top-end flow; so with the gears you have, the motor reaches some RPM (probably around 5000-5200), and plateaus. Produces no meaningful power beyond that. Can't go any faster because there's no flow.Heads come off of a 89 350 pickup
Get a set of decent heads.
Still seems fine for what you have...193 heads (1.94/1.50 valves, unless someone cut for larger exhuast valves), mild cam and headers.
Nothing to be ashamed about, you might find a few more ponies with tuning, but I don't think it'll drop you into the 13's if that's what you're after.
what kinda of heads? Can't really buy a aftermarket set funds low, but is there a good set that I can go get out of a junk yard? Or do I just need to save?
You can open yours up some...I think DynoDon did a set of 193's and gained 30RWHP.
You could find a set of L98 heads (083's) and work on them as well...Eventually you'll hit a limit, regardless of the heads, due to the cam, in act too much head and not enough cam will be a mismatch as well.
here are the specs to my cam if it helps.
intake@cam 2934 @valve440
exhaust@cam 3027 @valve 454 w/1.5 rockers I have 1.6
advertised duration intake 270 exhaust 276
If you need more I will type it up.......
