Speed-Pro Forged Pistons w/.001 Clearance???
Old 04-21-2004, 04:40 PM
TA-Wizard's Avatar
Car: 1988 GTA Notchback
Engine: 5.7 TPI
Transmission: TH-700R4
Just got a set of forged Speed-Pro 2256F skirt coated pistons. Instructions say to run them with .001 minimum clearance?????
I have been using Wiseco and JE/SRP for a few years, and have gotten used to .004-.005 clearance on forged pistons.
Does anyone run these pistons this tight??? What alloy is Speed-Pro using that does not expand as much as the others???
Old 04-21-2004, 04:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's the coating that makes the difference... just follow the instructions, all will be well
Old 04-21-2004, 04:59 PM
TA-Wizard's Avatar
Engine: 5.7 TPI
RB,
Do you use these pistons?? I checked the Speed-Pro website and the non-coated 2256 pistons also run a .001 min bore clearance.
What gives???? I am all for them using an advanced alloy, but, when every other forged piston I have used for the past 10 years is running at .004 minimum, it just makes me a little nervous.
I will be laying around a 200hp shot of juice on this motor and I don't want any problems.........
Old 04-21-2004, 06:17 PM
Damon's Avatar
I've used them. They'll be fine at .001. I do them about .0015 becuase I'm the nervous type, but like RB says- all will be well.
Forged pistons expand quite a bit more than cast or hypers. That's the main difference.
Old 04-21-2004, 08:09 PM
TA-Wizard's Avatar
Engine: 5.7 TPI
thats my question.....these ARE forged pistons.....so they will (should) expand more than cast or hypers. I have used various cast/hyper pistons fitted very tight (.001-.0025) with good success, but, forged are always at least twice the clearance of cast/hypers.
How in the world they can fit forged pistons to .001 is a sign that we are in the 21'st century I guess.
Old 04-22-2004, 03:25 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Think these have a special alloy, some silica or something in them. Even years ago the TRW forgings of the same number were spec'd at .0015, but I honed the cylinders to .003 anyway, they ran great at that. The coating may wear away pretty quick to give that little extra clearance.
Old 04-22-2004, 03:53 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yep, those Speedpro pistons are essentiall forged hypereutectic
pistons. Meaning they have large amounts of silicon in them.
NZKnight
10-15-2015 02:47 PM
LT1Formula
10-08-2015 08:34 PM
91 SrS
10-07-2015 04:32 PM
skinny z
10-05-2015 06:23 PM
hartsmike
10-02-2015 07:11 AM
Quick Reply: Speed-Pro Forged Pistons w/.001 Clearance???
