Air pump/tubing & pulley removal
Subscribe
May 25, 2005 | 12:28 PM
Have two v belt setups I am about to remove the air pump and all tubing on, couple questions ?
Best exhaust manifold plugs are 5/16 flared ?
After cutting air tube off flush at GUTTED cat, anything special needed to weld hole shut on cat ?
I even want to remove pulley that was driving the air pump, has anyone tried to separate the v belt pulleys ? I realize I would have to use a spacer instead of the pulley to locate fan properly ?
Thanks,
Bill E.
Reply 0
Subscribe
