what exactly is this piece?? all it looks like is a coupler between the fuel pump and the fuel lines but whats up with the metal part. when i went to put the new pump on this piece doesnt fit snugly but could i just use a piece of rubber fuel hose to connect the pump to the metal lines???
Fast355
close
- Join DateJan 2005
- LocationHurst, Texas
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car1983 G20 Chevy
- Engine305 TPI
- Transmission4L60
- Axle/Gears14 bolt with 3.07 gears
- Liked:509 Times in 437 Posts
Its the pulsator. Basically a muffler for the fuel system.
ah okay. so i can get away without using it and just connecting the pump and lines with a piece of hose?
Quote:
Yes, but it needs to be a specific fuel hose (this quote is from APEUSA.com, a place that sells Walbro fuel pumps):Originally posted by CamarosRUS
Quote:
If you need to use a piece of fuel hose inside your tank, be sure it is SAE J30R10 spec hose. That hose is high pressure fuel hose that was designed to be immersed in fuel. DO NOT use fuel hose that is designed for inline use only [SAE J30R9]. It will not survive inside the tank.
Quote:
I wish I read that before mistakenly installing the low pressure hose when I converted my 94' Suburban to TPI. The hose eventually split under the pressure. Luckily for me, the Suburban tank is easy to drop, unlike the 3rd gen cars. I had to buy a new pump to get the right hose, but it was worth the piece of mind.Originally posted by Benm109
Whatever you do, do NOT install the wrong hose:
Ed
