What size is this plug in intake baseplate?
Subscribe
Oct 13, 2001 | 09:19 PM
What size plug do I need for the large hole in the front of the intake baseplate (manifold)? It's the one that's under the two smaller holes. I was going to use the one out of my old engine but I can't get it out. Also what's this hole for in other applications?
Riccioli Performance Motorworks
--RPM Racing--
Getting there.....383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Now let's pray it runs when it's all back together!!!!
Reply 0
Oct 13, 2001 | 11:39 PM
If they go into the water passage then I can only guess at 1/2" pipe plug. I doubt it's as large as a 3/4" pipe plug and the smaller ones should be 3/8" pipe plugs.
Those holes are usually for heater hose ports and coolent sensors.
Reply 0
Oct 14, 2001 | 08:03 AM
I don't remember the exact size of the coolant passage hole, but it's bigger than 1/2". I recall using like a 20mm+ sized wrench to remove it awhile back. Probably 3/4".
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Reply 0
Subscribe
