I tried this on the TBI board and looked in the archives but no luck. Does anyone here know the GPH flow numbers for the 454 truck TBI fuel pump or even the 350 TBI fuel pump?
I know the numbers for the 305 TBI pump is 29 GPH @ 0 psi.Do the others flow more and if so how much? Will they fit in the 305 gas tank? HOpe someone knows. Thanks.........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake bored to 2", 65# injectors,454 TB, Command perforance custom chip(still tunning) ,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
