Someone recently told me that stock pistons can be used in a 350 that has been bored .30 over as long as over sized rings are used. I dont quite know what to think of this. I always thought that over sized pistons were needed. Anyone have any insight into this?
You'll have to measure the pistons to see if they're larger than stock. If they're a stock type replacement piston for an overbore, there should be a .030" stamped on them somewhere. You can't use standard bore pistons in an overbored cylinder. There's always a specific piston to wall clearance specification when installing pistons.
I think you can clean up the cylinders to around .010" over and still use factory pistons with oversized rings but that may even be too much.
Irockz
close
- Join DateMar 2005
- LocationSpringfield,Mo
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car87 Berlinetta,work in progress
- Engine468 BB,still in the build process
- TransmissionTH350,3500 stall
- Axle/Gears9" Ford,learning how to live under
- Liked:0 Times in 0 Posts
Someone gave you incorrect information,period.
You might could run stock pistons on a .010 over bored engine, I've ran a Briggs & Stratton lawnmower like that for years, it just rattles a little, but .030 would be out of the question, however if you bore the engine .30 over you wont have any cylinder walls left!!!
