proper fuel injectors?
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I have a 350 and am goin to convert over to the stealth ram. It has about 10:1 compression, comp cams XR276 hyd roller cam. I was wondering if 24 pph injectors would be enough or hurt anything. Until I get more money I will run my stock throttle body and 24pph injectors, if it is ok. Oh and I am burning my own chips so can change it later. Oh and who makes a good set of injectors that won't cost me an arm and a leg? Thanks for info.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Where are these so called 24pph injectors coming from??? brand name???
If you are talking about 24#/hr LT1 injectors you should be OK, but if you are talking 24#/hr SVO injectors that is another matter.
Car: 1991 Z-28
Engine: 350 SBC
I am not sure what brand they are, all I know is they are all black. They were in the car when I bought it and he said they were 24pph. So ford svo injectors flow more?
New2Chevy
Oct 4, 2015 11:27 PM
Firechicken86
Aug 12, 2015 10:07 PM
