Tpi-rpm-mpg
Subscribe
Oct 1, 2003 | 08:15 AM
I have a full size Blazer K5 with 350CID/TH350, 4.88 and 38" tires. When I am at 60mph my motor revs ~2500rpm, and I get a horrible MPG (around 10mpg).
I have a complete TPI from an 86 TA (305) and whas wondering if my mileage would be better with TPI than my Edelbrock 750.
The main conserne is how low gearing I have, and perhaps I am not gaining so much by changing to TPI.
The cost of the swap should be minimum, because I have everthing to do it except bigger injectors and chip.
So....do you think I will get more MPG with the TPI, and if so, how much better (15 MPG??)?
Nonni
86 TA, 305HO
81 Blazer K5
Reply 0
Oct 1, 2003 | 11:08 AM
Three things right off are hurting your mileage.
First it is a blaizer, not aerodynamic at all, it has to "blast" a hole in the air as it travels.
Second the TH350 is only a 3 speed, no overdrive.
Third your rearend gears, looks like it is geared to run the 1/8 mile.
Also, depending on how "built" your engine is that 750 carb might be too much.
I don't expect you'll see much of a gain with the TPI if everything else remains the same, assuming it is presently in a good state of tune.
Reply 0
Oct 1, 2003 | 12:54 PM
The gearing with 38" tires actually isn't sooooooooo bad, but the other points remain valid. The TPI might gain you a few, like maybe 2-3 MPG, but your main function should be to put an overdrive tranny in there or perhaps add an electronic overdrive from an older towing package to drop those revs.
A guy here at work had an '80's half ton Chevy 4X4 running close to 18 MPG highway on a 350 TPI with an overdrive AT in it. He said he had 33" tires and somewhere around 4:10 gears in it...
Reply 0
Oct 1, 2003 | 12:56 PM
Yeah, I know, my Blazer has is to move a lot of air, and it has no overdrive (to exspensive to change that).
The truck was built to use mostly off road, thats the reason I have so low gears, and it has a pretty big tires (38").
I was just wondering if there would be better to use that TPI I have, cause it will cost me very little to swap. TPI is also better than carb in very step hills. But if I will not see any gain in MPG then I will not do it.
My engine is in pretty good tune so perhaps its the best to stick with the carb
Thanks,
Nonni
Reply 0
Oct 1, 2003 | 01:06 PM
Quote:
Sell the TPI, then unload the TH350 trans once the 4 speed OD is in. You should come out ahead if you play the game right... not to mention the better mileage paying for itself eventually.
Reply 0
Oct 2, 2003 | 05:00 AM
I am sure it would be the best way in USA, but there is no market for TPI in Iceland. Used TH700 for 4x4 vehicles cost around $1000, if I could find one, and if I want to buy it from USA then I have to pay $$$$ in freight and custom duties.
Then I will have to move the transfercase and buy two new driveshafts. That swap will cost me at least $1500. I have consideret changing to TH700 but it will take a long time to pay for it self.
Changing to TPI should not cost me more than $300-$500, because I have everything (dont even have to plumb new fuel lines).
Nonni
Reply 0
Subscribe
