need new injectors for 355 tpi im going with the 24lb injectors. there listed on 50motorsports website as;
Ford Racing A302-24#
Modified 1985-91 350
Stock 1992-96 TPI
Flow Speced Set*
$329.50
http://www.fiveomotorsport.com/Injec...sTPI.asp#caddy
and summit has them listed as;
Ford Racing M-9593-A302 $289.95
http://store.summitracing.com/partde...5&autoview=sku
they are both the A302 part numbers, so many guys on this board sugest going to 50motorsports; would this set from summit be the same thing?
also i noticed that there are O-ring and hieght differences between the base and fuel rail between ford and gm injectors. but 5omotorsports says there A302 injectors will work in the TPI intake.
your thought and opinions, i could use the help with the decision.
Stock 1992-96 TPI
Flow Speced Set*
$329.50
Yeah, the Ford injectors will work fine in your TPI. Probably the only difference between the two sets you listed is that the more expensive ones are flow-matched. While that makes a small difference in performance, it's not really something you need to worry excessively about. In other words, if your budget is the bigger concern, just go with the ones from Summit. Some guys recommend using a set of the GM, blue injector o-rings with the Ford injectors to ensure against any leakage. The Ford o-rings are said to be slightly smaller in diameter compared to the GM ones.
where would i find the blue injector o-rings? would they be something i would pick up from gm, if so is there a part number you might have or somway i could reference it to gm?
thats a great price. guess im buying from ebay.
thanks for the link
thanks for the link
