TPi Fuel Lines
Subscribe
Jul 5, 2013 | 06:16 PM
Guys, need some help finding o-rings for the fuel line from the flex lines to fuel rail and new replacement flex fuel lines for my TPI. Called Advance, Napa, and Jegs with no success. The primary line is 3/8" and the return line is 5/16".
Reply 0
Jul 5, 2013 | 06:20 PM
Re: TPi Fuel Lines
They just rubber O rings. go get a box of assorted fuel grade o rings.
Reply 0
Jul 6, 2013 | 02:41 AM
Re: TPi Fuel Lines
Quote: , need some help finding o-rings for the fuel line from the flex lines to fuel rail The primary line is 3/8" and the return line is 5/16".
Viton
Return at fuel rail # -010
1/4"
3/8 "
1/16 ".
Supply at fuel rail # -011
5/16 "
7/16 "
1/16".
Reply 0
Jul 6, 2013 | 06:55 AM
Re: TPi Fuel Lines
Thanks and happy 4th !!!
Reply 0
Jul 6, 2013 | 10:41 AM
Re: TPi Fuel Lines
Thanks again, at least Napa carries o-rings ....
Reply 0
Jul 6, 2013 | 03:03 PM
Re: TPi Fuel Lines
Do you know the size of the 4 o-rings in the fuel rail assembly ?
Reply 0
Jul 6, 2013 | 03:37 PM
Re: TPi Fuel Lines
Got mine from autozone made to fit.
Reply 0
Jul 6, 2013 | 07:17 PM
Re: TPi Fuel Lines
Quote: Do you know the size of the 4 o-rings in the fuel rail assembly ?
-110
3/8"
9/16"
3/32"
Reply 0
Jul 6, 2013 | 07:41 PM
Re: TPi Fuel Lines
[QUOTE=Tuned Performance;5548924]-010 as56A ,1/4 id ,3/8 od
http://www.autozone.com/autozone/par...96537&cmpid=cj
SK24 in standard motor products or delco 217-440 The schrader valve is acdelco 15-31054
Reply 0
Jul 7, 2013 | 03:03 PM
Re: TPi Fuel Lines
I had new flex lines made at a local House of Hose for about $20. I brought them the fitting and they pressed on hoses and set me up with new o rings that were fuel rated. good luck!
Reply 0
Jul 8, 2013 | 09:24 AM
Re: TPi Fuel Lines
[QUOTE=Tuned Performance;5595065]
Thanks man!!!! I been calling around and looking around for this kit. Just ordered it. Sweet, hope to fire up the car this weekend.
Reply 0
Jan 5, 2015 | 11:18 PM
Re: TPi Fuel Lines
I need help! I need to know what's the size of O-ring number 224. I have tried three times and each time the fuel line leaked. I'm tired of driving around looking for the right O-ring. I'm banging my freaking head against the wall in frustration.
Reply 0
Jan 6, 2015 | 03:34 PM
Re: TPi Fuel Lines
I was under the impression that the Fuel O-rings were metric. 14mm for the return, 16mm for the input side. I bought a kit that had all of the orings iincluded on-line. Usually can get them on Ebay for about $10 for the kit.
Reply 0
Jan 6, 2015 | 11:31 PM
Re: TPi Fuel Lines
Quote: I was under the impression that the Fuel O-rings were metric. 14mm for the return, 16mm for the input side. I bought a kit that had all of the orings iincluded on-line. Usually can get them on Ebay for about $10 for the kit.
So just to be sure the one I'm looking for is the return o-ring correct? Ima go ahead and make a quick stop by Auto Zone one of these guys mentioned Viton and Auto Zone carries those.
Reply 0
Subscribe
