looking at ARP website wondering which wheel stud to use. Application is 1984 Z28 10 bolt rear end with Auburn pro series #3 carrier and yukon gear ring and pinion, and axles. Personal preference is ARP for all internal fasteners. I have located part #z for ring gear and flywheel but the stud selection is somewhat vague. Any info woul be greatly appreciated.......many thanx........
Assuming you have drum brakes, or at least the axles from a drum rear, use the studs for a late model drum brake rear. It's in the description when you download the catalog off the ARP website.
many thanx..................
Again Many thanx..........all taken care of.........rear is installed and undergoing break in at this time. thanx for the replies........Bill
Would that be the same for the 9 bolt also?
Kevin
Kevin
Wheel studs are the same for 9 and 10 bolts.Stock or aftermarket.
