I want to put a rearend off of either a 87-92 z28 camaro to get posi trac and rear disc brakes. Everytime I look up brake packages some say w/ 1LE perf. pack. or w/o 1LE perf. pack. Can anybody tell me the differences and which ones I would need to get???
with 1LE means the sway bar is bigger and rotors are bigger. Without is the production size sway bar and rotor. I think the 1LE came with dual piston calipers too. I am not positive. I have only seen one in person and that was years ago.
1LE makes no difference at all to the rear brakes.
Quote:
yes it does...in fact the braking system was the most upgraded part(s) of that package...go to www.1LE.netOriginally posted by Apeiron
heres a little list
Brakes:
Master brake cylinder: 18014286
Master brake cylinder piston (secondary): 18006832
Proportioning valve (2nd design, 1.5 tube nut threads): 10136840
Proportioning valve (1st design, 1.0 tube nut threads): 14089496
Front caliper bolt: 14084051
Front caliper bracket: 18016034
Front caliper retaining clip: 10132842
Front caliper LH: 10132827
Front caliper RH: 10132828
Front caliper guide pin: 10140666
Front caliper anchor plate LH: 10132829
Front caliper anchor plate RLH: 10132830
Front caliper bolt washer: 14080254
Front caliper hose LH: 10113075
Front caliper hose RH: 10113076
Front brake hose to caliper bolt: 14047782
Front brake hose to caliper bolt washer: 14076180
Front rotor (w/ hub and studs): 18016035
Caliper bleeder cap: 14089150
Front caliper bleeder: 14071826
Front caliper piston: 10104482
Front brake caliper guide pin boot: 14067552
Front hub outer bearing: 457049
Front brake pads: 10104485
Rear caliper plate and bracket bolt: 10112649
Rear caliper guide pin bolt: 14067559
Rear caliper mount bolt: 10097602
Rear caliper housing w/ piston LH: 10132831
Rear caliper housing w/ piston RH: 10132832
Rear caliper guide pin: 14067560
Rear caliper anchor plate: 10112652
Rear brake caliper guide pin boot: 14067552
Rear brake hose: 17688596
Rear brake hose to caliper bolt: 14047782
Rear brake pipe bracket: 10097601
Rear brake hose to caliper bolt washer: 14076180
Rear disk brake mounting plate: 10080876
Rear rotor: 10087702
Rear caliper bleeder cap: 14089150
Rear caliper bleeder: 14081826
Rear caliper piston: 10112643
Rear caliper piston seal: 14067562
Rear brake pads: 10132836
I have a 92 B4C which has 1LE brakes, and I can guarantee you, the rear brakes on a 1LE car are pretty much the same as any PBR disc brake rearend. Maybe they had different pads, or different part numbers or whatever from the factory. But when I checked em out to compare 1LE vs Z28 I found that the rear calipers are both the same PBR calipers, and the rotors/bolts/carriers are interchangable. At my local parts store the part numbers are the same to service either setup. After taking both apart with my own hands, it does not appear to me that the 1LE option has any sort of special rear brakes. The front brakes and proportioning valve, now thats a different story. Those are definately different.
Hey guys thanks for the help!
Quote:
heres a little list
No, it doesn't. Every single one of those so-called 1LE-rear brake parts is found on absolutely every other 89+ disc brake car.Originally posted by f-crazy
heres a little list
