I just did a drum to disc conversion on my 10 bolt. First was the removal of the axle shafts and backing plates from both rears. Next I reinstalling all the disc parts on to the 10 bolt. All went well. Now, I put the rear back in the car with new shocks, bolted in the rest of the suspension. I took the car out for a drive and I have a clanking, juggling noise coming from the rt. rear,when i hit bumps. I have know idea what I could be? It sound like its coming from the shock area from inside the car. Any help would be great!
I am having the same problem. I think I may have found mine though. Check your sway bar clearance in relation to your rear cover. Mine appears to be rubbing when I hit bumps.
Quote:
OK ill check it!Originally Posted by ttopformula88
