ALL third gen owners with 6 speeds!!!
Subscribe
May 15, 2007 | 11:41 PM
A common problem with the swap with a T-56 is the VSS has anyone hooked it up.... if so how did you do it this could help alot of members get their cars running correctly...
I just did the swap my self and now i have a code (check engine light) 24 which is no vss signal present and i have the dakota didgital box wired in correctly. any thoughts let me know.
thanks
Reply 0
May 15, 2007 | 11:51 PM
Re: ALL third gen owners with 6 speeds!!!
How do you have the box wired in? The directions are wrong. Its been a long while, but I think the directions tell you to use pin 4 and you need to use pin 3, or its the other way around. Is your speedometer on the dash working?
Search for "dakota digital" and you'll see the threads of everyone else who had that problem.
Reply 0
May 16, 2007 | 02:53 PM
ok I have the box wired in as follows.....
VSS from trans to ground and the other wire to my autometer spedometer.... the spedometer works fine.... then from the spedometer on the (out) terminal that runs to the dakota digital box and connects to (SIG IN) the box is also connected to ground and 12volt power properly, and then i have the wire connected to the computer from the (out 5) on the box...... IS this correct.... all i know is that the Dakota digital box is recieving a signal becasue the green light flashes when the car moves
also if it matters, its a 1986 camaro with a TPI setup, and it had a mechanical spedo
if any one has done this, try to help me hook this up right... the dakota digital techs seem confused, also iv searched and cant find exactly what i need..
THANKS
Reply 0
May 31, 2010 | 06:53 AM
did you ever find a solution to this ?
Reply 0
Subscribe
