i've never had my tv cable installed, ever... it's been dangling there since i got the car... i tried hooking it up once but nothing happened... it could've been misadjusted OR it doesn't work... how can i test the thing? if i can somehow pull the cable and set it temporarily, what should i expect when i drive the car as compared to having it the way it is? should it shift later? and up to what length can the cable be pulled? an inch? thanks for any help... sheesh, i sound like an idiot
i think that there is a post in the technical articles about adjusting the TV cable
TV Cable
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
