I recieved my Moser housing today and I am putting it in and just mocking it up before I paint it. I am also running a Spohn TA. It looks like there is no way to get the TA over enough to get the bolts through. It is hitting the E-brake cable brackets and fuel line mounts in the tunnel. Does anyone have any pics showing what they had to modify to get this thing to work? Any advice form others who have done this would be very helpful.
there should be 2 different sets of holes in the torque arm, you need to use the innermost holes, and even then the rear will rub the floor a little on the side of the tunnel, mine actually punched a hole in the floor with the top most bolts that holds the torque arm bracket to the rear.
If the torque arm does not have 2 sets of holes, you are screwed.
if it does and the arm is hitting the 3rd member before those holes can be used, you have the clearance the case a little. It will not affect the case strength. I had to file just a hair off my moser aluminum case to get it all to work, but i an using a UMI torque arm.
You also need longer bolts for the torque arm if you do not already have them
Awesome...mine only has one set of holes! It isn't a problem I could always drill another set. How far apart are the two sets of holes? I still need to get the center section, so I probably need to wait to redrill until I get in place to check for clearance. Nothing is easy!
I just talked to Spohn and found that the second set of holes is spaced 1". I am going to drill the second set of holes and see where those put me.
if you havent done it yet, i can measure mine tonight, i have the back of car all ripped appart so it wont be too hard
