One of the bolt holes on the shift linkage lever(the part that attaches the cable to the trans and is what actually physically changes the gears on it) is stripped out and I'm planning to put in a B&M shifter soon, would simply retapping the threads to a larger size be sufficient?
sure, that or replace the arm. or you mean a trans pan bolt? again, drill and tap, or a heli coil i suppose.
some of the bolts are drilled all the way though the case, others are not. be careful no to drill into the trans and make a leak
So a longer bolt might even fix it? But whatever the fix I need it to be pretty strong given the application. And the bolt holds the shift lever to the trans, but it also goes through the pan.
jmd
close
- Join DateJul 2000
- LocationAridzona
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car`86 SS / `87 SS
- EngineL69 w/ TPI on top / 305 4bbl
- Transmission`95 T56 \ `88 200-4R
- Liked:94 Times in 91 Posts
I'd heli-coil it; lucky for me I have M8x1.25 heli-coils in the garage.
If the bolt hole goes through the case to where a nut will fit it, that would work but be annoying.
Quote:
never said anything about a longer bolt, but probably not. I would try a heli coil firstOriginally Posted by Project 3.4 Camaro
So a longer bolt might even fix it? But whatever the fix I need it to be pretty strong given the application. And the bolt holds the shift lever to the trans, but it also goes through the pan. sofakingdom
close
- Join DateSep 2005
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,485 Times in 1,897 Posts
Yup, Heli-Coil is th eway to go.
