hope i didnt f*** up!
Subscribe
Jul 9, 2011 | 10:28 PM
well i was following the instructions on line for the t5 swap, and as for the shifter hole i did 22 1/2 from the bell housing, but the begining of my shifter hole is 5 inches from the round hole above it. seems pretty far. also the tranny just doesnt want to slide in, i get it about a 1'' away i hope i put the piolt bearing in far enough. it is almost flush.
Reply 0
Jul 10, 2011 | 08:51 AM
Re: hope i didnt f*** up!
Quote:
round hole above it
Not sure what that is? Never heard of such.
Pilot bearing should look about like this.
It almost sounds like maybe you have a S truck transmission though. Those won't work in these cars, not least because the shifter is located about 5" too far forward on the transmission's extension housing.
Reply 0
Jul 10, 2011 | 10:14 PM
i have a fbody transmission i took it out of a camaro, and the round hole is the one on the automatic cars for the shifter. about 1 1/2'' in diameter.
Reply 0
Jul 10, 2011 | 10:36 PM
Quote: i have a fbody transmission i took it out of a camaro, and the round hole is the one on the automatic cars for the shifter. about 1 1/2'' in diameter.
That hole is irrelevant in a T5 or T56 car; you'll be cutting a new hole for the T5 shifter.
Reply 0
Jul 11, 2011 | 12:10 AM
Quote: That hole is irrelevant in a T5 or T56 car; you'll be cutting a new hole for the T5 shifter.
i cut the hole but it seems pretty low.
Reply 0
Jul 11, 2011 | 06:55 AM
This is what the hole should look like, from the factory.
Reply 0
Jul 11, 2011 | 03:54 PM
heres mine
and heres one from a v6 manual third gen
Reply 0
Subscribe
