cant find carrier info
Subscribe
Nov 20, 2011 | 02:57 PM
i cant find what size carrier or spline i have to get a posi unit. i has number 2252676 on it but cant find anything on that number. anybody have any info on this rear? its an 84 z28
Reply 0
Nov 20, 2011 | 04:34 PM
Re: cant find carrier info
Providing it's still original, your 84 will have a 7.5" carrier for 26 spline axles. A 7.5/7.625" posi for 26 spline axles will be a direct bolt in. You just need to make sure it's the proper series for the gear ratio you want to use.
You can buy a 28 spline posi and upgrade your axles to 28 spline at the same time.
Reply 0
Nov 20, 2011 | 07:31 PM
Quote: Providing it's still original, your 84 will have a 7.5" carrier for 26 spline axles. A 7.5/7.625" posi for 26 spline axles will be a direct bolt in. You just need to make sure it's the proper series for the gear ratio you want to use.
how do i know what series it is? i wanna run either 3.73 or 4.10 gears
Reply 0
Nov 20, 2011 | 09:14 PM
3.73 or 4.10 will need a 3 series carrier unless you buy a thick gear set designed for a 2 series carrier. If you're ordering the posi at the same time as the gears then just buy them in the 3 series.
Reply 0
Nov 21, 2011 | 06:44 AM
Info below that you may find interesting:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Reply 0
Nov 21, 2011 | 04:02 PM
Quote: 3.73 or 4.10 will need a 3 series carrier unless you buy a thick gear set designed for a 2 series carrier. If you're ordering the posi at the same time as the gears then just buy them in the 3 series.
ok now my question is will the series 3 fit in my stock rearend? i kno nothing about rears so ur helping me out alot
Reply 0
Subscribe
