i have a bw super t10. its stock but i needed to remove the rear housing to replaced the seal and i noticed the reverse idler gear thrust washer was missing a piece out of it. I cant seem to find just the washer for it other than in a rebuild kit for richmond t10. I should be able to use richmond parts right? Or does anyone know where i can get just the washer?
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,485 Times in 1,897 Posts
Probably not an issue, unless you're planning on doing burnouts in reverse. I wouldn't bother.
Yes the Richmond one would work fine, as long as it's about the same thickness and the same ID & OD.
Sorry, I gave away / threw away / sold all my T-10 stuff about 20 years ago; I'm sure I got rid of several at that time.
Its the trans that was in it. Just need to get by til i get my t56. You said dont bother. Should i use it as is? It didnt seem to be an issue before i replaced the 305
sofakingdom
close
- Join DateSep 2005
- CarYes
- EngineUsually
Yup, run it.
