Hello. I'm having some weird activity when I let off my gas. Let's say I'm going 50 mph and I let off the gas. Once my rpm get to about 1500 it start to bounce around and you can hear the exhaust making a "drone" noise. Here's a vid I uploaded. https://m.youtube.com/watch?v=mJoPSGbCpuE
I don't see a problem if you are shifting thru gears. Fill out your profile so we can see and know what make and model you are working on.
Quote:
Thanks for the reply. I will upload another vid this one might not show like I want it to. Its like if its trying to figure out which gear to get in. You can hear the exhaust just "droning". Its hard to explain and it doesn't happen every time.Originally Posted by jazzdadss
I don't see a problem if you are shifting thru gears. Fill out your profile so we can see and know what make and model you are working on. Is it just the tach acting up or is the engine cutting out while this is happening? I see when your tach falls so does your oil pressure. almost like something was cutting fire to the engine.
Yes it's the engine cutting. U can hear it. When I press the gas it will stop.
