I have heard you all speak of upgrading the stall convertor from the 1900rpm to a 2500rpm-2900 rpm. what is the best to go with,where should I get it, and how much should I look to be spending(parts only because I would be doing it myself
thanks
Derek Johsnon
90 red rs 3.1 Mods--hypertech thermomaster chip, 160 degree thermostat, and K&N filter
Soon coming: 1.52 rocker arms, 3.73 , 2400rpm stall conv. compucam 2030, and msd 6a. all by christmas!!!
I Live my life a quarter mile at a time(the fast in the furious), only it takes me like 18 seconds to do it in this v6!!!
thanks
Derek Johsnon
Get your cam, gears and rockers in first, your stall woun't make a difference (or as much as it should) till atleast your cam is in.... Remember build the engine around the cam you use :P
David
David
I can't answer you question, but what is a stall converter?
Jeff
92 Camaro V6, mods: K&N, modified air box, JET chip 2,Dynomax Cat & Cat Back Systemwww.camarors.4t.com
Jeff
