Looking to buy a set of 15 inch IrocZ wheels only. They were 88-90 standard wheels. Lmk if there is a set out there. THANKS BOTCH1
I will be selling the set off my iroc soon.
Quote:
Whee are you located and how much do you want for the rims. Is there any blems in the faceOriginally Posted by cliff1970
i have a silver set in case your still looking we are going to the Cleveland ,ohio area Friday if somebody wants them. I can load them up.
IROCs all got 16 s . the 15s were plain Z wheels
They did make a 15 incher, Standard wheel was a 15 inch IROC rim look alike, not the old Z28 wheel.
JamesC
close
Quote:
Yep.Originally Posted by B4C5.7
They did make a 15 incher. JamesC
[QUOTE=B4C5.7;5977792]They did make a 15 incher,
2nd that! I wish somebody would buy mine! lol!
I got a pair, I just need to clean them up and get some tires mounted
I'm trying to use oven cleaner to eat the paint and clear off the rims so I can paint the insets yellow and reclear them. I heard from someone that it works, but it doesn't seem to be working. Anyone have any suggestions on something that'll eat the paint and clear off the rim without hurting the aluminum. Many thanks
Brake fluid goes through paint like nothing else! I've heard of guys using on plastics but not too sure about wheels, It might be ok as long as you made sure it was really clean afterwards. Or just find a good paint stripper chemical!
Quote:
Edit, don't use brake fluid, I was kidding. Try something like thisOriginally Posted by meanZ86
Brake fluid goes through paint like nothing else! I've heard of guys using on plastics but not too sure about wheels, It might be ok as long as you made sure it was really clean afterwards. Or just find a good paint stripper chemical! http://www.rustoleum.com/product-catalog/consumer-brands/auto/paint-chemicals/aircraft-remover/
I used aircraft stripper, worked like a charm
